May 4, 2021 at 11:16 am
atulsingh92
SubscriberMay 4, 2021 at 12:13 pmAmine Ben Hadj Ali
Ansys EmployeeIf you go back to the circles created from GUI and try to re-do the same using TUI will it work?
May 4, 2021 at 1:13 pmRob
Forum ModeratorWork through the whole command and read what Fluent asks for, it may want x1, x2, x3, y1, y2, y3 or x1, y1, z1 or some combination of. Ie type
/surface/plane-bounded/
and then follow the prompts
May 4, 2021 at 1:39 pmatulsingh92
SubscriberThats what I did exactly.
Becuase there is has to be a manual entry to select where the coordinates should be. It becomes difficult to find a squarish plane that coevers the whole circular periphery.
Also there are 3 points required in the prompt (x0y0z0, x1y1z1 and x3y3z3) that defines this plane. But how the bounds are to be controlled for the plane, is something that is not clear!
May 4, 2021 at 2:42 pmAmine Ben Hadj Ali
Ansys EmployeeA plane is defined by three points or a point on a plane and its normal. Again: if you repeat the first working circle with TUI will it work or not?
Viewing 4 reply threads- The topic ‘Bounded plane tool using TUI’ is closed to new replies.
Ansys Innovation SpaceTrending discussions- air flow in and out of computer case
- affinity not set
Top Contributors-
3977
1461
1272
1124
1015
