May 3, 2021 at 2:42 pm
Luiz
SubscriberI'm trying to export the mesh I did on Ansys on a modal analysis. I've tried to right click over modal on mechanical and "export nastran file". But when my friend tries to import this .bdf file on HyperMesh, the result is not good, she cannot see anything, just some random nodes, not even the 3D component is there. Any tips on how to export correctly? Or even export to Optistruct would be helpful, as she doesn't have ansys there.
May 3, 2021 at 2:53 pmLuiz
SubscriberAdditional information, her Hypermesh is version 2017.2 and my Ansys is 2020 R1.
May 5, 2021 at 3:44 ampeteroznewman
SubscriberI have successfully used the Export Nastran File button in ANSYS Workbench 2020 R1. I both ran a Modal analysis in Nastran and opened the model in the Femap Pre/Post processor.
One tip is to use Linear Elements.
Another tip is to use only Hex elements or Tet elements.
Don't have an ANSYS mesh that has any Pyramid or Wedge elements.
May 6, 2021 at 11:24 amLuiz
SubscriberPerfect, when I converted to linear elements and Tet elements only, it worked perfectly well
Thanks
Viewing 3 reply threads- The topic ‘How to export to NASTRAN (.bdf) file or to Optistruct (.fem) file?’ is closed to new replies.
6550
1311
