How to have contour of torque
    • ahmedshafie
      I want to make contour of torque in fluent or in cfd post
    • DrAmine
      You need to create additional variables to store the torques and forces to do that.
    • DrAmine
      Please for the future raise the question in the appropriate category.
    • ahmedshafie
      what variable do i need to create?
    • ahmedshafie
      thanks for choosing the appropriate category i didnt know wich one is better
    • DrAmine
      You require a user defined function with a user defined cell memory in Fluent which will store force or moment for every single face at the wall in question. With CFD-Post there is no option to show force values as contour plots.
    • DrAmine
      But you can show pressure and wall shear stress values which are basis of force /moment. You might create then additional variable which stores expressions in which you formulate the pressure and viscous force
    • ahmedshafie
      thanks for your help
Viewing 7 reply threads
  • The topic ‘How to have contour of torque’ is closed to new replies.
