Preprocessing
Preprocessing
Named selection in the mesh isn’t available in the setup display
    • Hazem
      The named selection "Blade walls" is already defined in the mesh. But  isn't showing in the setup display when I check the mesh before proceeding to solve.
      Even though it was there just before I updated the mesh for a few edits and all of a sudden it's gone from the setup.
      I've attached pictures.
    • Keyur Kanade
      close fluent.
      please right click on mesh and use clear mesh data.
      then again right click and generate mesh.
      on workbench main page, right click on mesh and click 'update'.
      now open fluent. it will ask to update the geometry/mesh. please select yes.
      let us know if this works for you. if it works, please mark this as 'is solution' to help others on forum.
    • Hazem
      Thank you so much for your reply. Can you please clarify where to find "clear mesh data" and "generate mesh". And is this going to delete any of my work inside the mesh or not?
    • Keyur Kanade
      select 'mesh' in model tree.
      use right click.
      click 'generate mesh'
    • Hazem
      That worked. Thank you so much sir, Appreciate it .
Viewing 4 reply threads
  • The topic ‘Named selection in the mesh isn’t available in the setup display’ is closed to new replies.
