Ansys Learning Forum Forums Discuss Simulation General Mechanical Problem in ANSYS Static structural Simulation Reply To: Problem in ANSYS Static structural Simulation
Harish_s
nThanks for your suggestion.nI will explain the steps followed:nI created the intersection curve between the two surfaces and fitted the spline as a single sketch. nThen, created a plane to sweep the circular crosssection through the 3D spline sketch nThen, I converted the solid model to IGES format (as recommended by you).nThen I imported in SpaceClaim geometry for beam extraction.nnBut, when I tried to extract beams, the operation failed. nThis is my core problem.nAnd I could not create that 3D sketch in Spaceclaim due to limitations in the software, like, there is no option for creating the intersection curve.nKindly give your suggestion.n
