Ansys Learning Forum Forums Discuss Simulation Fluids Highly coupled UDS Transport equations Reply To: Highly coupled UDS Transport equations
Surya Deb
Hello, nAre you using a Coupled PT solver? nDo you solve the UDS and the flow variables simultaneously? If the UDS properties are not tightly coupled to the flow, then can you converge the flow field first, then freeze the flow and solve for the UDS?nWhat discretization schemes are you using?.Regards,nSuryan
