Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › how I can Assume/assign electrodes on my solid structural ? Help please!! › Reply To: how I can Assume/assign electrodes on my solid structural ? Help please!!
February 8, 2021 at 4:18 pm
Dear,nThank you for your quick response!nI have already read the couple field analysis Guide and also all the examples related to Electrostatic-Structural Analysis but I still could not figure it out. I have attached the command I used for my simulation for you valuable feedback. because whenever I run the simulation I got this error:n*** ERROR *** CP = 49.594 TIME= 23:46:26n Specified constraint not allowed on slave degree of freedom in coupled n set. n Coupled set number 10 First node= 58802 Slave node = 66002 Degree of n freedom = VOLT. n Move Move constraint to first node or remove coupling and constrain nnThank you in advancen
