Ansys Learning Forum Forums Discuss Simulation Fluids how can i get the values of heat gained by a certain surface and air in a box subjected to sun Reply To: how can i get the values of heat gained by a certain surface and air in a box subjected to sun
Use surface and volume reports. These need to be set up and monitored during the solution. The data file for Fluent contains instantaneous values and not the solution history. n
