Ansys Learning Forum Forums Discuss Simulation Electronics SCRIPT RUNNING ERROR Reply To: SCRIPT RUNNING ERROR
rtk
,nThis error usually appears due to some of the below causes:nAnsys tool installed on a server and you are trying to run the script from the client machine.nMissing Library... can consider re-installing the Ansys tool and check. (Uninstall completely and then install through proper channel)nDue to permission problemsnHope this info can sort out the issue. Please let me know if you have any further questions.nnBest Regards,n
