In this tutorial, you will learn how to:
This tutorial shows you how to simulate the flow around a given “standard” wind turbine rotor using Ansys Fluent. The rotor geometry is shown in the figure below. The hub is neglected for simplicity since it doesn't contribute to the power generated by the rotor. Only one blade is considered in the simulation setup by using periodic boundary conditions. The simulation yields the velocity and pressure fields around the blade and the power generated.
The following document lists the steps of this tutorial with general directions.
