The following video covers the procedure for setting up residuals, adding monitors and running the case.
Note for learners who are recomputing solutions for different tip speed ratios: After changing the rotation rate under "Cell Zone Conditions," recalculate the solution WITHOUT redoing the initialization. If you initialize from the inlet again, it will once again take 1300 iterations or so to converge, but if you recalculate from the previous solution, it will take a fraction of that time.
