Note: You have the option of skipping the Geometry and Mesh steps in Ansys by downloading this file here containing the mesh and loading it into Ansys.
The following video shows the procedure of meshing fluid domain around wind blade using Fluent Meshing.
To avoid meshing issues at the trailing edge, under the ‘Advanced Options’ of “Generate the Surface Mesh”, turn off the “Auto Remesh to Remove Clustering” (from ‘Auto’ to ‘no’ ) as per below.
Download the mesh file here.
