The following video shows how to save and play the animation.
VIDEO
Change the window to display the moment monitor. Note the oscillatory behavior.
Review the animation.
Expand Animation in the Outline, under Results. Double click "Solution Animation Playback."
Change "Write/Record Format" to MPEG and click Write.
It will be located in the working_folder /MFR_files/dp0/FFF-1/Fluent.
You can delete the .hmf files.
Save the Project.
After running steady-state and transient cases, we can compare both in single CFD-Post session. The same procedure is shown in the following video.
VIDEO
Text summary of the above video
Back to Workbench, drag "Solution" from MFR into Results of the Sliding Mesh.
Double click Results to open CFD-Post.
Compare results side by side:
Enable two windows view.
Change on to the MFR and the other to the Sliding Mesh at 1.5s.
Enable "Sync Views."
Change to the Velocity Contours.
Review.
Change the variable to "Velocity in Stn Frame" and click Apply.
Review the Vorticity Contours.
Review the Turb KE Contours.
