Slug Flow Model Lesson-2
This lesson covers the concept of Slug Flow Model in the context of two-face flow and heat transfer. It delves into the understanding of non-dimensional numbers to specify the velocity of the slug bubble, predicting the velocity using drift flux model and laminar regime, and calculating the film superficial velocity around the gaseous plug inside a vertical tube. The lesson also explains the assessment of pressure drop inside the horizontal slug flow. It uses a schematic to illustrate the repetitive pattern of gaseous Slug and gaseous plug and liquid slug. The lesson further discusses the calculation of terminal velocity of a bubble, liquid film superficial velocity, bubble velocity in horizontal slug flow, and pressure drop inside a horizontal slug flow.
Video Highlights
01:15 - Slug flow model with a schematic diagram.
04:15 - Calculation of the terminal velocity of the bubble of the gaseous plug.
12:18 - Discussion on the pressure drop in Slug flow.
17:33 - Explanation of the horizontal slug flow model.
25:49 - Assessment of the pressure drop across the horizontal slug flow.
Key Takeaways
- The Slug Flow Model is used to understand the velocity and pressure drop in two-face flow and heat transfer.
- Non-dimensional numbers are crucial in specifying the velocity of the slug bubble.
- The drift flux model and laminar regime are used to predict the velocity of the slug bubble.
- The film superficial velocity around the gaseous plug inside a vertical tube can be calculated.
- The pressure drop inside the horizontal slug flow can be assessed.
- The terminal velocity of a bubble, liquid film superficial velocity, bubble velocity in horizontal slug flow, and pressure drop inside a horizontal slug flow can be calculated using specific formulas.
