This lesson covers the in-depth analysis of transformers, their construction, and operation. It explains the equivalent circuit of transformers, the analysis of ideal transformers, auto transformers, and three-phase transformers. The lesson also discusses various tests like open circuit, short circuit, and Sumpner test. It further elaborates on the parallel operation of transformers and the construction details of small and large transformers. The lesson also explains the concept of specific magnetic loading and specific electric loading, and how these factors influence the size of the transformer. The lesson concludes with a discussion on the necessity of cooling in large transformers.
01:13 - Explanation of the construction of transformers, including the difference between small laboratory transformers and large power station transformers.
09:59 - Discussion on the KVA equation of a transformer and how it relates to the size of the transformer, specific magnetic loading, and specific electric loading.
12:53 - Explanation of how the temperature of a transformer rises during operation due to copper loss and iron loss, and how it attains a constant temperature when the rate of heat generation matches the rate of heat dissipation.
32:05 - Discussion on how the KVA rating of a transformer can be increased by increasing all the linear dimensions of the transformer, while keeping the specific magnetic loading and specific electric loading constant.
38:36 -Explanation of how the increase in the size of a transformer affects the heat dissipation and the need for cooling arrangements.
