This lesson covers the concept of parallel operation of transformers, an important topic in electrical machines. It explains the process of connecting two transformers in parallel, the conditions required for this operation, and the implications of different voltage and KVA ratings. The lesson also discusses the importance of the quality and magnitude of the leakage impedances of the transformers. Using an illustrative example, it demonstrates how the load current is shared between two transformers with different KVA ratings and how the load demand can be met by connecting more transformers in parallel.
02:20 - Explanation of how the load is shared between two transformers connected in parallel.
06:08 - Discussion on the importance of the ratio of the currents in the transformers for better load sharing.
16:26 - Explanation of the conditions required for meaningful parallel operations of transformers.
22:03 - Explanation of how the KVA is supplied by the transformers in parallel operation.
