Restarting Failed Optimization Analysis
Question – How do you implement the instruction recorded in a failed Topology Optimization output?
Answer -The message is usually triggered because the final iterate does not satisfy all constraints. User can insert a command object in the environment branch with "RELOAD_DENSITY=TRUE"
This will enable the topology optimizer to pick up where it left off.
