OC and SC Test on Synchronous Generator — Lesson 12
This lesson covers the intricate details of salient and non-salient pole synchronous machines. It delves into the process of drawing phasor diagrams and the conditions under which these machines operate. The lesson also explains the difference between generator and motor modes, and how power is delivered or absorbed depending on the mode. It further discusses the impact of field current and bus voltage on the operation of these machines. The lesson concludes with a detailed explanation of short circuit and open circuit tests on non-salient pole synchronous machines. For instance, it explains how to calculate the value of Z by measuring the short circuit current and the open circuit voltage.
Video Highlights
01:06 - Impact of field current and bus voltage
07:16 - Explanation of short circuit and open circuit tests
22:34 - Phasor diagram of a salient pole machine generator under short circuit condition
Key Takeaways
- Salient and non-salient pole synchronous machines operate differently under various conditions.
- The phasor diagrams are essential for understanding the operation of these machines.
- The field current and bus voltage significantly impact the operation of these machines.
- Short circuit and open circuit tests provide valuable insights into the operation of non-salient pole synchronous machines.
