Applying Force in Local Coordinates Using Commands — Lesson 4
How do you apply nodal force in a local coordinate system?
To apply the force in local coordinate system:
  1. Create the local coordinate system and activate it.
  2. Use the command NROTAT to rotate the nodal coordinate system into the active system.
