How do I use a Turbulence model and the non-Newtonian model at the same time?
Run the TUI command below to use a non-Newtonian model while also using a Turbulence model (i.e. use the non-Newtonian power law with the Carreau model, Cross model, or Herschel-Bulkley model):
/define/models/viscous/turbulence-expert turb-non-newtonian? yes
