Effect of Discrete Random Walk Dispersion Model on the Particles Trajectories — Lesson 5
What does the discrete random walk dispersion model do with the particle trajectories?
The turbulent dispersion model adds a fluctuating component of the fluid velocity to the mean velocity.
This affects the particle trajectory through the drag force.
The actual distance traveled is obtained by considering all the particle forces and integrating the particle force balance with this updated fluid velocity.
