Generating Animations after CFD Simulation Run.
Is it possible to create a video in Ansys Fluent after the CFD Simulation run.
No it is not possible. The dat file contains only the last time step information.
In order to create a video, you have to specify the animation setup before running your simulation or you have to save all the data file for each time step.
