Vibration Noise Coupled Model
Describe the vibration noise coupled model.
Features of the noise and vibration coupling model:
- Displacement mode of the structure
- Sound pressure of the sound in the region contour and SPL variation
The acoustic is not only a single fluid sound, you may need a case for the vibration sound of the structure to be connected. The analysis and the structured value of the walls is caused by the fluid force. Additionally, the vibration source is typical.
For more details on vibration noise coupled model, refer to this document.
