How do you use remeshing together with the Ansys Fluent adjoint mesh morphing capability for large boundary deformation?
For large mesh deformations with the Ansys Fluent adjoint solver design tool, it is possible that the mesh quality deteriorates up to a point in which the flow solution is no longer accurate enough. If you have a tri (2D) or tet (3D) mesh, you can use the dynamic mesh capabilities of Fluent software to improve the mesh quality in between design iterations.
The attached document describes the necessary steps and possible pitfalls of using dynamic mesh settings during design iterations, including possibilities to automate the process.
You can access the relevant files by clicking on this link: Download Files
