Exporting Flow Results from Ansys Fluent on Ensight Domain Boundaries
How to export flow results from Ansys Fluent on domain boundaries in EnSight case Gold format?
This is actually possible if one toggles on the 'EnSight Parallel' in export dialog after selecting the “EnSight Gold” export format.
Note that you can either export solution data from Cell Zones or Surfaces, but you cannot do both at once.
Please also note that this export capability is only possible if you are starting parallel (not serial) Ansys Fluent.
