Changing Units in Ansys Ensight Tool
How to change unit in Ansys Ensight software?
1- Global units might be changed before loading the case: Edit/Units.
2- With the calculator toolbox you can either use predefined functions or define your own equation using math operators and functions.
3- To change the Units Display, Create/edit Annotation (Legends) is used.
Please refer to the attachment to access the Video Solution.
