What is the most efficient way to compare results on clip planes for very large (>100M element) cases?
1. For each geometry
a. Load case in SOS (Server of Servers)
b. Create clip planes (x,y,z), using plane tool with finite clip extent
c. Calculate variables on clips and surfaces
d. Save Ansys EnSightâ„¢ simulation data visualization software Case Gold files for clips and surfaces (consider grouping, ie all x clips in one file) with File > Export > Geometric > select Case (Gold)
2. Start a new non-SOS session of Ansys EnSight tool
a. Load reduced case files for each geometry (non-SOS)
b. Use CaseMapDiff
