Turbulence Eddy Frequency and Turbulence Eddy Dissipation Correlation
Could you explain how in Ansys CFX the Turbulence Eddy Frequency and the Turbulence Eddy Dissipation are correlated? Is it defined as omega = epsilon/k?
From the fact that the turbulence eddy viscosity is defined as
in k-epsilon model: mu_t = C_mu*rho*k^2/epsilon
and
in k-omega model: mu_t = rho*k/omega
we can conclude that
Turbulence Eddy Frequency = omega = 1/C_mu*epsilon/k
