Hostname of the Machine
Parallel run does not start because connection to machine fails, although its hostname mas34xxx.local is entered in the host.ccl file. Why?
The hostnames in the host.ccl file have to follow some rules. They must not contain points '.' or underscores '_' and they must start with a character.
So the hostname of this machine has to be changed.
