Now, we will look at the results of the simulation.
In the Outline window, click the temperature solution we created
. You should see the following
The temperature is 122 degrees Celsius throughout, which is to be expected.
In the Outline window, click the deformation solution we created
The maximum deformation is 0.002 m, which matches our boundary condition.
In the Outline window, expand the beam tool folder, and click on Direct Stress. You should see the following
The stress is constant throughout.
