Final Challenge - Lesson 9
It's now time to create a model on your own! The challenge for you is to create a solid model of an air conditioner (AC).
What is an Air Conditioner (AC)?
An air conditioner is a machine that removes heat and moisture from an enclosed space and helps maintain the temperature at a desired level​. It is one of the most widely used consumer products around the globe.​
Modeling approach:
For this design challenge, you should follow the same approach we've learned in the previous lessons. Download the technical drawing required for creating this challenge model here. Examine the technical drawing and come up with a plan for how to create the geometry and features as efficiently and accurately as possible. Good luck!
Check out the video below for some helpful tips on how to build this air conditioner model.
Alternate video link.
