How do you rename a trace in 2D result plots?
In the Project Manager > Results > (2D plot name), left-click on the trace you want to rename. The properties window below the project manager will show “Specify Name” with a checkbox. This needs to be checked to enable editing the name. Once you check “Specify Name,” it will let you rename the trace. You cannot rename it from the legend.
