Design of Experiments — Lesson 5
This step samples specific points in the design space. It uses statistical techniques to minimize the number of sampling points since a separate FEA calculation (and associated stiffness matrix inversion) is required for each sampling point. This is the most time-consuming step in the optimization process.
Response Surface Optimization
First, Goal Driven Optimization needs to be placed in the Project Schematic. In the left-hand menu called "toolbox" expand Design Exploration. Next, drag Response Surface Optimization and drop it right underneath the Parameter Set. Your project schematic window should look comparable to the one below. Note that all the systems are connected.
Next, double-click Design of Experiments. Again, we can see our input and output parameters but this time they appear under the Design of Experiments step.
Highlight P1-DS_R and change the Lower Bound to 1 inch and the Upper Bound to 2.5 inches.
Now that the radius of the hole is properly constrained click on
. The Ansys software picks what it thinks are the best sampling points according to an algorithm. Note that these sampling points are not necessarily linearly spaced. To get a numerical solution for each of these radii, click Update.
If you get the following error, click Yes.
Twiddle your thumbs a bit while the software performs some time-consuming matrix inversions.
After the update has completed, click on Return To Project. You may want to save again at this point.
