After understanding why parametric analysis and optimization is necessary, we look at a simple example to understand input and output parameters. You will explore why PIDO is needed instead of manual, time-consuming optimization. PIDO is the key to finding better designs in less time.
00:55 - Why to do parametric analysis?
01:32 - What are the Input and Output Parameters
