Numerical Results — Lesson 7
Once the solution is complete, check the Total Deformation 1 to 5. These deformations are mode shapes corresponding to its mode frequency.
If you click on the Solution, tabular data will be displayed at the bottom of the window. This tabular data shows a frequency value corresponding to each mode. The data in the table should look as below.
| Mode | Frequency(Hz) |
| 1 | 158.18 |
| 2 | 160.84 |
| 3 | 166.12 |
| 4 | 166.68 |
| 5 | 383.71 |
