This lesson discusses the requirements and evolution of different standards, mechanisms to meet new requirements, and the propagation characteristics. The lesson also delves into the concept of MIMO (Multiple Input Multiple Output) and its role in improving spectral efficiency. It explains the capacity enhancement by sending parallel data streams and the impact of spatial fading correlation on capacity. The lesson concludes with the motivation for studying massive MIMO. For instance, if you have a matrix with two columns and four antennas, you're essentially taking two vectors that take two data inputs and send them out over four such antennas. This lesson concludes with the spatial fading correlation.
00:18 - Introduction
04:03 - How to use scalar spatial data pipes
19:38 - Water pouring algorithm
24:44 - per stream rate control and how to reduce feedback
35:10 - Code book index
40:49 - Spatial fading correlation
- The 5th generation communication system has evolved with different standards and mechanisms to meet new requirements.
- MIMO plays a crucial role in improving spectral efficiency in any broadband wireless communication system.
- The capacity can be enhanced by sending parallel data streams.
- Spatial fading correlation can impact the capacity of the system.
- Massive MIMO is studied due to its potential to increase capacity without increasing transmit power.
