MIMO Signal Processing - Part III — Lesson 3
This lesson covers the signal correlation model and its effect on the system's performance. It introduces the concept of capacity in MIMO and its significance in enhancing spectral efficiency. It also covers the impact of correlation on error probability, showing that correlation increases the error probability. This lesson concludes with the concept of Channel unknown to the transmitter.
Video Highlights
00:15 - Introduction
03:36 - Signal correlation model and how it affects the performance of the system
10:51 - Concept of capacity in MIMO systems
15:19 - Error free spectral efficiency
21:30 - Channel unknown to the transmitter
Key Takeaways
- Multiple antenna signalling schemes enhance reliability and spectral efficiency.
- The dominant Eigen mode plays a crucial role in signal processing.
- The Eigen mode significantly influences the Signal-to-Noise Ratio (SNR).
- The signal correlation model can affect the performance of the system.
- The concept of capacity in MIMO is vital in enhancing spectral efficiency.
