This lesson covers the concept of isotropic processes and how to calculate the reduced pressure using the actual pressure ratio. It also explains the alternative method for using the air table and how to retrieve the value for h2s. The lesson further discusses the concept of entropy and how to calculate it for different states. It also provides a worked example of an ideal Brayton cycle and explains how to calculate heat, power output, thermal efficiency, and the second law efficiency. The lesson concludes with a discussion on the concept of exergy and how to calculate the rate of exergy destruction in the components.
00:08 - Introduction to alternative method for using air table
09:59 - How to apply steady flow energy equation to compressor and turbine
17:53 - Concept of compression with intercooling
20:54 - How to determine optimal intermediate pressure for compression with intercooling
24:57 - How to apply same considerations to isentropic expansion process
- The Brayton cycle is a thermodynamic cycle that describes the workings of a constant pressure heat engine.
- Intercooling is a process used to increase the efficiency of gas compressor systems by reducing the temperature of the air before it enters the compressor, thereby decreasing the work the compressor has to do.
- The steady flow energy equation can be applied to different components of the Brayton cycle to calculate the heat supplied, power output, thermal efficiency, and second law efficiency.
- The concept of exergy is crucial in identifying areas for improvement in the Brayton cycle.
- Multi-stage compression with intercooling can reduce the power required in each stage of compression, thereby increasing the overall efficiency of the cycle.
