Brayton Cycle — Lesson 5
This lesson covers the understanding of the Brayton cycle, a thermodynamic cycle that describes the workings of a constant pressure heat engine. The lesson delves into the specifics of the cycle, including the isentropic efficiency of the turbine and compressor, the parameters that control the performance of the cycle, and the effects of pressure ratio on efficiency and specific work. It also discusses the insights obtained from an air standard analysis and the impact of assuming air to be calorically perfect. The lesson further explains the use of air tables for more accurate calculations and ends with an example of a compressor's workings.
Video Highlights
01:52 - Comparison of ideal and actual cycle
03:34 - Limitations of assuming air to be calorically perfect
05:10 - Explanation of air table
07:15 - How to use air table
14:44 - Example of using air table in compressor
Key Takeaways
- The Brayton cycle is a thermodynamic cycle that describes the workings of a constant pressure heat engine.
- The isentropic efficiency of the turbine and compressor plays a crucial role in the Brayton cycle.
- The parameters that control the performance of the cycle are T3 over T1 and Rp (pressure ratio).
- The effect of pressure ratio is generally to increase the efficiency and specific work.
- Air tables are used to account for variations in specific heat capacity with temperature, providing more accurate values for specific power and efficiency.
