Questions
How can I process tabular data files in Python?
How can I visualize it?
Objectives
Explain what a library is and what libraries are used for.
Import a Python library and use the functions it contains.
Read table data from a file into a program.
Create some simple visualizations
Lecture
VIDEO Alternate video link
Jupyter Notebook File
Please use the Jupyter notebook named "02AnalyzingRadianceData.ipynb " for this lesson. If you haven't downloaded them already, you may find them here
Key Points
Import a library into a program using import libraryname.
Use the numpy library to work with arrays in Python.
Use array[x, y] to select a single element from a 2D array.
Array indices start at 0, not 1.
Use low:high to specify a slice that includes the indices from low to high-1.
Use the pyplot module from the matplotlib library for creating simple visualizations.
