Transformer with Multiple Coils — Lesson 7
This lesson covers the concept of ideal transformers and their role in circuit analysis. It delves into the intricacies of how to solve circuits involving several ideal transformers. The lesson explains the concept of impedance and how it gets transferred across the secondary coil of a transformer. It also discusses the concept of voltage per turn, which remains constant in several coupled coils. The lesson further elaborates on how to calculate the induced voltage. The lesson also provides a detailed explanation of how to calculate currents in all the windings of a transformer when different switches are closed.
Video Highlights
03:55 - Discussion on the concept of voltage per turn
04:23 - Calculation of induced voltage
10:15 - Explanation of how to calculate currents in all the windings of a transformer
17:00 - Detailed analysis of calculating currents when different switches are closed
Key Takeaways
- An ideal transformer is a simple yet interesting component in circuit analysis.
- The concept of voltage per turn is crucial in calculating the induced voltage in a transformer.
- The currents in all the windings of a transformer can be calculated by considering the status of different switches.
- The fundamental rule in transformer analysis is that the flux in the core of the transformer cannot change, regardless of the positions of the switches.
