Sample LessonSample LessonSample LessonSample LessonSample LessonSample LessonSample Lesson
Fluid Flow Simulation in Discovery
Welcome to the world of fluid flow simulation! This course is designed to help you master Ansys Discovery, a powerful tool for simulating fluid flow.
In this Lesson we will cover the basic UI of Discovery and then go over an end-to-end fluids analysis, from Geometry preparation to setup and at the end some post processing features with comprehensive report generation. Let’s get started!
