The goal of this part is to guide you through converting a fluid flow simulation into thermal fluid flow in Ansys Discovery. Building upon the concepts introduced in our previous part on cutter bodies and basic fluid flow conditions, we will continue from the existing setup. If you're new to this setup, consider reviewing the last lesson or downloading the provided setup file for a seamless start.
Simulation Files
Download the files here to follow the video step-by-step. Ansys Student can be downloaded for free here.
