This lesson covers the process of defining governing equations and adding boundary conditions in Ansys Fluent® fluid simulation software. It explains how to set up the Ansys Fluent launcher, perform a mesh check, refine governing equations, and specify material properties and boundary conditions. For instance, the lesson demonstrates how to change the solver type to density-based, enable the conservation of energy equation, and specify the properties of the flow fluid. It also guides on how to set the gauge total pressure, specify the supersonic SL Inlet gauge pressure, and set the total temperature.
