Convergence testing is a procedure where you vary the simulation settings and find the required settings for accurate results. In this video, we will take an SOI waveguide example and demonstrate how to run various convergence tests to obtain accurate simulation results.
See the Related Links for more examples of convergence testing on simple waveguide systems that have an analytic solution.
