Modeling Signal Inputs with Ansys HFSS Using Wave Ports and Lumped Ports — Lesson 2
When modeling an electromagnetic structure, the accuracy of the solution solver is dependent on the input signal definition, also known as the excitation. This excitation can be defined as a port on the geometry model. Ports can define either an input signal or an output signal. Ansys HFSS is a finite element electromagnetic solver that provides several ways to excite the model geometry. The excitation signal can be defined as a power, voltage, or current source. The most common port types used are wave ports and lumped ports. This lesson details the key points for defining these ports along with their differences and uses.
Alternate video link.
