Customize Material Properties
Is it possible to customize the material properties like Specific Heat and Thermal Conductivity in a Thermal strain simulation?
No, these properties are currently not customizable by users. The stability of the simulation is sensitive to the defined material properties and to keep convergence maximized, these types of temperature-dependent properties as not exposed to the user for customization.
