Simulate Parts Attached to Baseplate
In Additive Print Product, are there any instructions for simulating parts attached to the baseplate with minimum support height = zero?
When you simulate a part directly on the baseplate with minimum support height set to 0, there are variations in the assumptions at the bottom of the part depending upon the outputs a user selects. Varying combinations of "Simulate Part on Baseplate without Additional Supports" and "Displacement After Cutoff" settings result in different assumptions.
The attached article describes the different assumption variations-
