How to use parameters in Ansys Fluent without Workbench? How to access parameters in Ansys Fluent via TUI commands in a journal?
Parameters can be accessed in Ansys Fluent in the Text User Interface (TUI) under:
/define/parameters
First you have to enable the access.
/define/parameters/enable-in-TUI y
Then you can change a value of an input parameter, e. g.:
/define/parameters/input-parameters/edit t_in , 999
This changes the value of an input parameter “t_in” to a value of 999.
