How to enable the use of Parameters in Ansys Fluent TUI?
It is possible to enable the use of parameters in Ansys Fluent using Text User Interface (TUI).
In order to create parameters through the TUI, the following option needs to be enabled
/define/parameters/enable-in-TUI? yes
